Peloton Tread Replacement Walking Belt
Peloton Tread Replacement Walking Belt image 1
Peloton Tread Replacement Walking Belt image 2
Peloton Tread Replacement Walking Belt image 3
Peloton Tread Replacement Walking Belt image 4
Peloton Tread Replacement Walking Belt image 5
Peloton Tread Replacement Walking Belt image 6
1 / 6
This is a Treadmill Doctor Peloton Tread Replacement Walking/Running Belt.
Used on the Peloton TR02
This Belt Will Not Work On the Tread+
The Peloton Tread Walking Belt is a high-quality replacement belt made of durable materials. It provides smooth and reliable performance during workouts.
Moreover, it is pre-lubricated to minimize friction and ensure a quiet operation.
This Treadmill Doctor walking belt comes with a one-year warranty that covers defects in materials and workmanship in commercial settings.
Additionally, we boast a lifetime warranty for residential users.
Compatibility
This pliable walking belt is exclusively compatible with the Peloton Tread treadmill. It is not designed to fit other treadmill brands or models.
Working
The walking belt is the essential component that moves underneath your feet as you walk or run on the treadmill. A motor drives it and works with the treadmill's deck and rollers. When you turn on the treadmill, the belt begins to rotate, allowing you to walk or run.
Uses
The Peloton Tread Model Walking Belt is used for various fitness activities, including walking, running, jogging, interval, and incline training.
Over time, the walking belt on a treadmill can wear out due to many factors.
  • Improper maintenance: Failing to clean or lubricate the belt regularly can lead to premature damage.
  • Natural wear and tear: Even with proper care, belts can naturally wear out over time.
  • Overloading the Treadmill: Exceeding the treadmill's weight capacity can strain the belt excessively.
If you notice any or more of the following signs, it may indicate that your Peloton walking belt needs to be replaced.
Price for all 3 items $223.97
More from Peloton
Peloton Bike+ Replacement Drive Belt Part Number SP15-img
Part number: SP15
Peloton Tread Motor Drive Belt-img
Peloton Tread Walking Belt Lubricant-img
Part number: Peloton Slip Coat
Peloton TR02 Replacement Deck-img
BowFlex Max Trainer Drive Belt Part Number 1000415074 / 8004642-img
Part number: 1000415074
Cybex Walking Belt Part Number BD-22463-img
Part number: BD-22463
Tunturi Drive Belt Part Number 443-4007-img
Part number: 443-4007
Bowflex Saftey Key KK-6178-T
Part number: KK-6178-T
Proform PF CT1160 Console Overlay-img
$89.99
