Concept 2 Indoor Rower Thirty Inch Footstrap Replacement - Part Number 1517
Part number: 1517
Replacement nylon footstrap with buckle. This footstrap is approximately 30 inches long by 1 inch wide with a screwhole drilled approximately 9Inches from the buckle end.
Used on the Following Models Listed Below.
Concept II-
Model D Indoor Rower - After 07-19-12 - Black
Model D Indoor Rower - After 07-19-12 - Light Gray
Model D Indoor Rower - Between 07-31-06 & 07-19-12 - Light Blue Gray
Model E
Concept II-
Model E
More from Concept 2
Concept 2 Indoor Rower Chain Axle Replacement Kit - Part Number 1915
Part number: 1915
Concept 2 Indoor Rower Shock Cord Replacement - Part Number 1731
Part number: 1731
Concept 2 Indoor Rower Twenty-Four Inch Footstrap Replacement - Part number 1501
Part number: 1501
Concept 2 Indoor Rower Handle Replacement Kit - Part number 1931
Part number: 1931
Matrix Drive Belt Part Number 1000494771 / 004193-D
Part number: 1000494771 / 004193-D
Treadmill Doctor World Famous Treadmill Lubricant (3 pack)
Part number: world famous lube 3pk
Treadmill Doctor World Famous Treadmill Lubricant (4 pack)
Part number: world famous lube 4pk
