Recommended Lube When Replacing Treadmill Motor image 1
Recommended Lube When Replacing Treadmill Motor image 2
Discover the secret to a quieter, more efficient workout with our premium lubricant—your treadmill will thank you!
Treadmill Doctor World Famous Lube is a top-tier silicone-based lubricant expertly crafted to optimize the performance of your treadmill. This outstanding lubricant minimizes friction between the treadmill belt and deck, ensuring a smooth and efficient workout experience.
Not only does it enhance the functionality of your equipment, but it also significantly extends the lifespan of your treadmill, saving you money in the long run. Ideal for both residential and commercial use, this versatile lubricant is also compatible with most ellipticals and other fitness machines.
Key Features
  • USA Made Quality: Premium treadmill lubricant manufactured in the United States with high-grade materials for optimal performance and longevity
  • Easy Application: Convenient application ensures precise and even distribution of lubricant for maximum effectiveness and minimal waste
  • Enhanced Protection: Treadmill Doctors World Famous Lube Specialized formula designed to reduce friction between the belt and deck with our Proprietary ingredients that actually repels dust and dirt which is the #1 killer of a treadmill, minimizing wear and extending the life of your treadmill.
  • Performance Boost: Helps maintain smooth treadmill operation by reducing motor strain and preventing belt sticking during workouts
  • Maintenance Essential: Regular application helps prevent costly repairs and maintains optimal belt performance for a quieter, smoother exercise experience
Usage Instructions
  1. Safety First: Turn off and unplug your treadmill for safety.
  2. Preparation: Lift the treadmill belt slightly.
  3. Lubrication: Apply a small amount of lube directly under the belt.
  4. Even Distribution: Spread the lube evenly by hand.
  5. Testing: Plug in and turn on the treadmill at a slow speed for 3-5 minutes to ensure even distribution.
  6. Cleanup: Wipe off any excess lubricant.
Why Choose Treadmill Doctor World Famous Lube?
With just one application every 12 to 18 months, you’ll experience the difference in performance and maintenance ease because World Famous Lube doesn't evaporate like regular silicone. Treat your treadmill to the care it deserves with our World Famous Lube, and feel the difference today!
Price for all 3 items $60.97
More from Treadmill Doctor
3-In-One Household Oil-img
Part number: 3in1
Part number: GS Repeat
Loctite-img
Loctite
Part number: Loctite
Allen Wrench-img
Allen Wrench
Part number: 128457
Belt Dressing-img
Belt Dressing
Part number: BeltDressing
Matrix Walking Belt Part Number 1000471188-img
Part number: 1000471188
Bowflex Max Trainer Resistance Motor Part Number 1000415102 / 8004601-img
Part number: 1000415102
$44.99
Pacemaster ProPlus II Treadmill Safety Key Part Number APPKEY-img
Part number: APPKEY
Pacemaster Silver Select XP Treadmill Safety Key Part Number APPKEY-img
Part number: APPKEY
Silicone Treadmill Lubricant-img
